SEG - safe for now?
2 minutes ago, Radian said:
If only you could have powered the trip with the temperature gradient between the two ends. 🙃
Powered it with caffeine and cheese sandwiches.
And 9 gallons of diesel, which is cheaper in Oxford than down here for a change.
Edited by SteamyTea
  • Replies 82
  • Views 14.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I wouldn’t make any decisions on renewables based on SEG or any other scheme the Government sees fit to come up with. My plan is still to consume as much as we can generate/store. Any payments for exc
  • A problem we have at the moment is just about every heat pump has a TOTALLY different way of connecting to the required controls and by default only operates from it's own supplied controller which te
  • Perhaps sit on BuildHub typing "The correct unit is kWh" over and over?
Posted Images
57 minutes ago, SteamyTea said:
I moved all my possessions down in two trip in an old Corsa.  That included my very long ladder, which I got rid of the other day.
Im impressed. Ive always thought living "light" was a good idea.
I just cant do it myself. Ive no idea what i would do all day?
Save me the bother correcting the (expletive deleted)ing (expletive deleted)
Could easily be coded to automagically change it.
Not really. The most common mistake is to use kW where kWh is intended, but kW is often used appropriately too. I don't think AI is at the stage where it could handle the distinction perfectly, but even if it were, the forum software isn't capable of doing this.
And kw/h, Kwh, kwH, KWH, KW/h, KW/H.
We should, as a species use the correct units of energy the joule, not Joule (unless referring to the man or at the beginning of a sentence).
MJ is the more appropriate unit, 1 million joules, there are 3.6 MJ in a kWh, or 1 MJ is 0.2778 kWh when rounded to 4 decimal places, but in reality, 2 decimal place would do, so 0.28 kWh to the MJ.
One from Scottish Power. Seems the pros cant even get the units right so there's no hope for the rest of us
