"Thermo-acoustic" heat pumps
Nick Thomas
2 hours ago, Nick Thomas said:
Via a friend:
https://www.pv-magazine.com/2023/01/02/residential-thermo-acoustic-heat-pump-produces-water-up-to-80-c/
Interesting concept, although I hope they can make it work with something other than helium. At ten bar, it *sounds* a bit scary, although I imagine it's actually less hazardous than an unvented cylinder.
I would be more worried at diesel engines running 2000bar in injector rail..but there has been no issues over the last 15-20years.
A virtually incompressible fluid will have less energy in it than a compressible one, for the same pressure.
It is why pressure vessels are tested with oil.
14 minutes ago, SteamyTea said:
tested with oil
Just to be pedantic - normally water, depending on vessel material and end user this water is treated to remove certain minerals etc.  Large vessels are infrequently tested with air/nitrogen, because the stored energy within a compressed gas.  Went to a heat exchanger manufacture once and the heat exchanger (printed circuit heat exchanger) was for a gas service and the company would only perform air tests.  The test were completed ex WW2 bunker with 2m thick wall in case of mechanical failure.  You had to witness the test via a camera in another building.  The walls had big chunks out of then were a heat exchanger had failed in the past.
