Andeh Posted January 2, 2023 Posted January 2, 2023 I have a really awkward run to get my inlet and outlet pipes through to the ceiling. Metal rigid Ducting is killing me, trying to find a routing! Lost several hours and still struggling. Is there an equiv to the 125mm smooth bore Ducting the installer used to connect the MVHR to the rooms. Due to a poor installer letting me down, I'm stuck trying to resolve this myself! Thanks in advance.
PeterW Posted January 2, 2023 Posted January 2, 2023 Yes you can use 125mm convoluted aluminum duct but make sure you insulate it 1
IanR Posted January 2, 2023 Posted January 2, 2023 Could you use something like Lindab Tectherm to get through the awkward area? https://itsolution.lindab.com/lindabwebproductsdoc/pdf/documentation/ads/lindab/technical/tecflex400.pdf I used the Ø250 for some of my inlet/outlet route and works fine. 1
Andeh Posted January 2, 2023 Author Posted January 2, 2023 (edited) Thanks both. Would the below be suitable? I think 1.5m would do me length wise! https://www.amazon.co.uk/125mm-1-5m-Aluminium-Ducting-Hose/dp/B09LZXD82Y/ref=sr_1_3?crid=30E7ELZ0O4UXD&keywords=Aluminium+Air+Ducting+125&qid=1672678764&refinements=p_76%3A419158031&rnid=419157031&rps=1&s=diy&sprefix=aluminium+air+ducting+125%2Cdiy%2C1049&sr=1-3 Edited January 2, 2023 by Andehh
Nickfromwales Posted January 2, 2023 Posted January 2, 2023 You can get the Ubink 125x 4x 92mm manifold, convert to multiples of smaller 92mm ducts to get through the pinch-point, and do the same to get back again. 1
Andeh Posted January 2, 2023 Author Posted January 2, 2023 Thanks, frustratingly I have managed to route it....there is just so little space to insulate it & seal each joint (roof vents & worried about water ingress) that I want to test other options before I doom myself to kissing goodbye to the skin on my knuckles! I have ordered a length of the above to test it, so fingers crossed!
Nickfromwales Posted January 2, 2023 Posted January 2, 2023 1 minute ago, Andehh said: Thanks, frustratingly I have managed to route it....there is just so little space to insulate it & seal each joint (roof vents & worried about water ingress) that I want to test other options before I doom myself to kissing goodbye to the skin on my knuckles! I have ordered a length of the above to test it, so fingers crossed! I use the Illbruck 330 foam to insulate where other materials are impractical / impossible to install effectively.
Andeh Posted January 2, 2023 Author Posted January 2, 2023 Aaaah, expanding foam.... my second true love these days!! At times 1st true love..
