Vera16 Posted December 8, 2022 Posted December 8, 2022 For whatever reason (have parted company with builder so...) the window measurement was 10cm out and I have a huge gap under the lintel. I am considering the best way to fill this? The plus side is the window will not be very visible from the outside as it looks out onto a narrow passageway. I am think of glueing a block of wood painted in the same colour and then foaming to fill the remaining space. Does this sound sensible?
Onoff Posted December 8, 2022 Posted December 8, 2022 You can get upvc extensions to go at the header like this: https://www.ebay.co.uk/itm/362475908487 However...you really want to get the same make to ensure it clips in properly.
Vera16 Posted December 8, 2022 Author Posted December 8, 2022 The window is actually aluminium-clad timber (Norssken).
craig Posted December 8, 2022 Posted December 8, 2022 (edited) Timber head extension insulation between brick and extension, then attach some plasterboard and then finish it off, you wouldn't know it was there. Edited December 8, 2022 by craig
Vera16 Posted December 9, 2022 Author Posted December 9, 2022 I am not familiar with the term ‘timber head extension insulation’. Is that a product?
craig Posted December 9, 2022 Posted December 9, 2022 I meant to say to a timber extension (packer) to the head (top) of the window, with insulation between that and the brick.
