GreenGables Posted December 1, 2022 Share Posted December 1, 2022 Does anyone know if you can add extra insulation on top of a finished GRP roof? We may need to add more so looking at the best way to achieve this. Is it best to take off the whole roof and start again or can additional insulation board be added on top and then another GRP top layer added. At the moment we have plywood, vapour layer and possibly too little insulation with GRP top coat. Thanks for any advice.. Link to comment Share on other sites More sharing options...
SteamyTea Posted December 1, 2022 Share Posted December 1, 2022 Can't see any reason why not. Stick some PU sheet down with a resin mix, then sheath as usual. Link to comment Share on other sites More sharing options...
PeterW Posted December 1, 2022 Share Posted December 1, 2022 Yep bond down glass tissue covered PUR or similar then overcoat it with another top layer - it’s how a lot of commercial roof panels are done. Link to comment Share on other sites More sharing options...
SteamyTea Posted December 1, 2022 Share Posted December 1, 2022 38 minutes ago, PeterW said: glass tissue covered PUR Yes, forgot to mention that. All PU sheets used with GRP should be coated in it. Link to comment Share on other sites More sharing options...
GreenGables Posted December 1, 2022 Author Share Posted December 1, 2022 Thank you both. That is really good news. Link to comment Share on other sites More sharing options...
