Angelheart Posted November 26, 2022 Share Posted November 26, 2022 Long story short… I have asked a National company to replace my fascias and soffits. They sent out surveyor and he took a piece of material away to test and turns out my very small soffit is chrysotile cement board type. So they are already charging an extortionate amount so I enquired about getting it removed myself a couple of days prior to installation. They have said this is fine but they need a clean air certificate in order to proceed with the install following the removal. As this is all outside, surely it would just be measuring the cleanliness of the countryside air, I don’t get it. Can anyone shed any light on this nonsense? Many thanks Link to comment Share on other sites More sharing options...
markc Posted November 26, 2022 Share Posted November 26, 2022 Talk to another company, also send a sample in for your own benefit. It’s probably cement board so only precautions are don’t smash it, don’t grind it, wear a decent mask and it must be put into closed bags and taken to disposal site (informing them what you have). Link to comment Share on other sites More sharing options...
Angelheart Posted November 26, 2022 Author Share Posted November 26, 2022 Thanks Mark, they sent me a report back with the details on. Do you still think I should send off my own? I’m sure it can be removed in whole pieces and they are just making extra work and expense. I think they said if it was unlicensed then they would have removed it themselves but as it is licensed then they won’t. Link to comment Share on other sites More sharing options...
Conor Posted November 26, 2022 Share Posted November 26, 2022 When it comes to asbestos, it's best leaving it in place, as the risk only arises when cut/drilled/ground/smashed etc. Pretty standard practice to fit PVC fascias over existing ones. Link to comment Share on other sites More sharing options...
Angelheart Posted November 26, 2022 Author Share Posted November 26, 2022 It’s just the soffit Conor, not the fascia as well and it’s only a very small depth and amount. I’ve paid for full replacement and they have hold of my £800 deposit. Link to comment Share on other sites More sharing options...
Gone West Posted November 27, 2022 Share Posted November 27, 2022 @Angelheart I used an asbestos self test and found the whole inside of my old bungalow was lined with Chrysotile panels and the roof tiles were also Chrysotile. I had the panels removed professionally and removed and bagged the roof tiles myself which were then removed by the company. They did a clean air test inside but not outside. I would always do my own test as I do not tend to trust companies like that. That is further backed up by the fact they are asking for an outside clean air test. https://www.amazon.co.uk/Asbestos-Sample-Testing-Instructions-Postage/dp/B0862B9JZB/ Link to comment Share on other sites More sharing options...
