Hi,
we are midway through our timber frame house.
We are now installing internal VCL and (as always) I am checking if all is being doing correctly when it is already done.
seeing another post about vcl last night made me think if I am actually doing mine correctly.
our wall buildup is as follows feom out to inside:
- timber open screen  cladding
- UV membrane
- 25mm horizontal battens
- 25mm vertical battens
- external vcl
- osb
- 140mm timber frame
- 120mm insulation in between
I then installed internal VCL, and aim to cover with 50mm PIR, then service battens and plasterboard.
is it non-conventional?
most importantly, is it ok? It’s done now…
I was going to ask a similar question.
The air tight barrier generally goes on the warm side of the wall. However I’m also thinking doing as you’re doing. Our timber kit build up is a full filled 302mm CPS space stud, 9mm OSB, air tightness barrier, 25mm service void, 12.5mm plasterboard. I was thinking of filling the service void too.
3 hours ago, BartW said:
Hi,
- UV membrane
- external vcl
- osb
All the TF that I do have the barrier directly behind the PB
But would the way I have done it be ok?
I hope so, internally it's very similar to ours: brick outer skin, 50mm gap, beather membrane, 11mm osb, 140mm frame with 120mm pir, then VCL (airtight membrane), with 40mm of pir over the top, 25mm mm battens then plasterboard.
