BartW Posted November 26, 2022 Posted November 26, 2022 Hi, we are midway through our timber frame house. We are now installing internal VCL and (as always) I am checking if all is being doing correctly when it is already done. seeing another post about vcl last night made me think if I am actually doing mine correctly. our wall buildup is as follows feom out to inside: - timber open screen cladding - UV membrane - 25mm horizontal battens - 25mm vertical battens - external vcl - osb - 140mm timber frame - 120mm insulation in between I then installed internal VCL, and aim to cover with 50mm PIR, then service battens and plasterboard. is it non-conventional? most importantly, is it ok? It’s done now…
Kelvin Posted November 26, 2022 Posted November 26, 2022 I was going to ask a similar question. The air tight barrier generally goes on the warm side of the wall. However I’m also thinking doing as you’re doing. Our timber kit build up is a full filled 302mm CPS space stud, 9mm OSB, air tightness barrier, 25mm service void, 12.5mm plasterboard. I was thinking of filling the service void too.
nod Posted November 26, 2022 Posted November 26, 2022 3 hours ago, BartW said: Hi, we are midway through our timber frame house. We are now installing internal VCL and (as always) I am checking if all is being doing correctly when it is already done. seeing another post about vcl last night made me think if I am actually doing mine correctly. our wall buildup is as follows feom out to inside: - timber open screen cladding - UV membrane - 25mm horizontal battens - 25mm vertical battens - external vcl - osb - 140mm timber frame - 120mm insulation in between I then installed internal VCL, and aim to cover with 50mm PIR, then service battens and plasterboard. is it non-conventional? most importantly, is it ok? It’s done now… All the TF that I do have the barrier directly behind the PB
BartW Posted November 26, 2022 Author Posted November 26, 2022 3 hours ago, nod said: All the TF that I do have the barrier directly behind the PB But would the way I have done it be ok?
Roundtuit Posted November 26, 2022 Posted November 26, 2022 8 minutes ago, BartW said: But would the way I have done it be ok? I hope so, internally it's very similar to ours: brick outer skin, 50mm gap, beather membrane, 11mm osb, 140mm frame with 120mm pir, then VCL (airtight membrane), with 40mm of pir over the top, 25mm mm battens then plasterboard.
