Just had a preliminary air test on masonry new build flat roof bungalow before I start plaster boarding...Is 1.03 airtightness and 1.3 ACH good at this point? Is it financially worth pursuing lower?
  • Like 2
a few small areas around box lintel welds and around large bifold threshold which will be foamed and tiled over, walls have had a single coat of cement slurry...so probably better when boarded and plastered
Edited by gravelrash
Sounds pdg* to me 👍🏼
The additional points you mention are worth addressing if simple to do and not expensive, but otherwise you should be chuffed with those numbers.
* pretty darned good.
12 hours ago, gravelrash said:
second preliminary
Put the obvious bits right and ask him to do a free secondary report.
Then offer to sell your services as a quality manager.
