Construction Channel Posted June 23, 2017 Share Posted June 23, 2017 Firstly there doesn't seem to be a section for stairs..... unless i haven't looked hard enough?? secondly, how do I upload an excel/numbers file? i thought about Dropbox but it seems to need each person's email to allow access i just made this spreadsheet for a friend to try and prove a point, would someone be so kind as to check my workings, I wrote it in "numbers" apples version of excel, which annoyingly works in radians, It seems to be giving the correct answers but it is always best to put it to peer review before i start publishing things Link to comment Share on other sites More sharing options...
ProDave Posted June 23, 2017 Share Posted June 23, 2017 Rename the file .txt Upload it, with the instruction to rename it correctly (.xls?) before trying to open it. 1 Link to comment Share on other sites More sharing options...
Construction Channel Posted June 23, 2017 Author Share Posted June 23, 2017 please change .txt to the extension in the brackets. hopefully this works spindle machine (.numbers) .txt spindle machine (.xlsx) .txt Link to comment Share on other sites More sharing options...
Ferdinand Posted June 23, 2017 Share Posted June 23, 2017 Numbers file would be a .csv . If the Gaffer has banned .xls that would be due to virus potential etc. One bodge is to change the file type, and people who download change it back to .xls. Or upload elsewhere and link. I think you can set a file to be public on Dropbox or Google Drive. Ferdinand Link to comment Share on other sites More sharing options...
Construction Channel Posted June 23, 2017 Author Share Posted June 23, 2017 2 minutes ago, Ferdinand said: Numbers file would be a .csv . If the Gaffer has banned .xls that would be due to virus potential etc. One bodge is to change the file type, and people who download change it back to .xls. Or upload elsewhere and link. I think you can set a file to be public on Dropbox or Google Drive. Ferdinand i thought they used to be .csv but the save file seems to be.numbers also do you know how to make it public on dropbox? these are the only options it is giving, (this is the free version lets not talk about google drive. I fell out with that a long time ago Link to comment Share on other sites More sharing options...
Ferdinand Posted June 23, 2017 Share Posted June 23, 2017 (edited) I think you use a Dropbox thing called a 'shared link', which lets anyone with the link access the file. Thusly: Quote Share a link Sign in to dropbox.com. Hover your cursor over the file or folder you'd like to share and click Share when it appears. If a link hasn't been created, click Create a link. If a link was already created, click Copy link. The link will be copied to your clipboard. You can then paste it to an email, message, or wherever people can access it. https://www.dropbox.com/help/files-folders/view-only-access I think they can download but I have not tested it. Will test without being logged in if you post one. F Edited June 23, 2017 by Ferdinand Link to comment Share on other sites More sharing options...
Construction Channel Posted June 23, 2017 Author Share Posted June 23, 2017 https://www.dropbox.com/sh/n4dsl4ncdsztytx/AACcRLgTvBK7WFLLtygl7UhZa?dl=0 5 minutes ago, Ferdinand said: I think you use a Dropbox thing called a 'shared link', which lets anyone with the link access the file. Thusly: https://www.dropbox.com/help/files-folders/view-only-access F TYVM, It appears that option is only available if you access dropbox through a browser, for some reason it is just not there if i try it through the app.... hopefully the above link works Link to comment Share on other sites More sharing options...
Ferdinand Posted June 23, 2017 Share Posted June 23, 2017 Just now, Construction Channel said: https://www.dropbox.com/sh/n4dsl4ncdsztytx/AACcRLgTvBK7WFLLtygl7UhZa?dl=0 TYVM, It appears that option is only available if you access dropbox through a browser, for some reason it is just not there if i try it through the app.... hopefully the above link works Now, where is that bluddy acronym dictionary? Seems to work and give a list of directions for backgammon or something. Link to comment Share on other sites More sharing options...
Construction Channel Posted June 23, 2017 Author Share Posted June 23, 2017 2 minutes ago, Ferdinand said: Now, where is that bluddy acronym dictionary? https://www.google.com/#q=tyvm Link to comment Share on other sites More sharing options...
