MDC Posted October 26, 2022 Author Posted October 26, 2022 11 hours ago, PeterW said: Sorry did we find out how far this willow is from the house ..? Also - if you’re on piles today then it’s for a reason.. I would be more concerned with this first When the present house was built in 1953, there were no trees. The house sits at the top of a hill in a clay field. It was originally a bungalow, so it possibly safe to assume the foundations are shallow by today's standards. Why would it be on piles?
PeterW Posted October 26, 2022 Posted October 26, 2022 Salix Alba within 15m of foundations on high plasticity soils (ie clay) would need 1.8m foundation with clay heave protection. Removing it would require the same foundations and treatment so why not leave it and go piled foundations …?
PeterW Posted October 26, 2022 Posted October 26, 2022 35 minutes ago, MDC said: so it possibly safe to assume the foundations are shallow by today's standards. Why would it be on piles? Those 2 statements are conflicting - piles will be deep to get to a reasonable strata (assuming they are full piles..?) but could just be short piles and a reinforced ring beam to stop it moving on the clay. Have you done any ground investigation ..? And have you exposed any of the pile itself ..?
saveasteading Posted October 26, 2022 Posted October 26, 2022 5 hours ago, MDC said: Less than 16 metres If the tree was there when the house was built then it needed footings of over 2m, or piles.
MDC Posted October 26, 2022 Author Posted October 26, 2022 4 hours ago, saveasteading said: If the tree was there when the house was built then it needed footings of over 2m, or piles. The tree was planted after the bungalow was built.
MDC Posted October 26, 2022 Author Posted October 26, 2022 9 hours ago, PeterW said: Those 2 statements are conflicting - piles will be deep to get to a reasonable strata (assuming they are full piles..?) but could just be short piles and a reinforced ring beam to stop it moving on the clay. Have you done any ground investigation ..? And have you exposed any of the pile itself ..? No ground investigation. I got the information from house plans. Thank you for your advice.
Mr Punter Posted October 26, 2022 Posted October 26, 2022 I would remove the willow now and replace it with something that will not cause issues for your future plans.
Jilly Posted October 26, 2022 Posted October 26, 2022 Am I being dim, but can the piles be reused, if you are building on the same footprint?
MDC Posted October 27, 2022 Author Posted October 27, 2022 13 hours ago, Mr Punter said: I would remove the willow now and replace it with something that will not cause issues for your future plans. I now agree. I was looking at some Weeping Willows by the Thames yesterday. I thought the tree in question, by the house on my plot, is big, but I see it isn't by comparison, so if it stays, there will be considerably more trouble down the line.
MDC Posted October 27, 2022 Author Posted October 27, 2022 12 hours ago, Jilly said: Am I being dim, but can the piles be reused, if you are building on the same footprint? The new build will not be entirely on the same footprint. You have me wondering if the original piles will be left in situ or dug out.
PeterW Posted October 27, 2022 Posted October 27, 2022 25 minutes ago, MDC said: You have me wondering if the original piles will be left in situ or dug out. Usually chew or break the tops off about 8-900mm below ground and leave them - and hope they aren’t in the way of something ..!
saveasteading Posted October 27, 2022 Posted October 27, 2022 With no offending trees you don't need to go deep, so piling should be unecessary (it is expensive). It might be worth incorporating the existing piles but it will depend on type of pile, the beam of slab design, and positioning. Good fun for your SE.
Mr Punter Posted October 27, 2022 Posted October 27, 2022 My brother has a few willows in his garden. His house is on clay soil and was piled about 25m deep. He had an orangery fitted and just used a raft foundation. A couple of years later disaster. The orangery has now been removed, having settled so the doors would not open and it was causing damage to the house.
saveasteading Posted October 27, 2022 Posted October 27, 2022 19 minutes ago, Mr Punter said: about 25m deep Not on clay surely? Perhaps if on silt. 4m would be usual in clay. But yes, changing the foundation type so dramatically is likely to cause trouble.
MDC Posted October 27, 2022 Author Posted October 27, 2022 51 minutes ago, Mr Punter said: My brother has a few willows in his garden. His house is on clay soil and was piled about 25m deep. He had an orangery fitted and just used a raft foundation. A couple of years later disaster. The orangery has now been removed, having settled so the doors would not open and it was causing damage to the house. Crikey, that's a story. Point noted.
Mr Punter Posted October 27, 2022 Posted October 27, 2022 47 minutes ago, saveasteading said: Not on clay surely? Perhaps if on silt. 4m would be usual in clay. But yes, changing the foundation type so dramatically is likely to cause trouble. Yes, clay, which is what caused the heave. Probably silty clay and variable strata. The house is on a hill but about 70 metres from a river. They had to pile down to rock.
saveasteading Posted October 28, 2022 Posted October 28, 2022 On 27/10/2022 at 18:14, Mr Punter said: clay, which is what caused the heave. Clay heave of the orangery with shallow founds, attached to an immovable house. Understood. But I am unaware of clay heaving below 4m as it should be constantly damp. Maybe a clay I don't know of. My point is not the differential movement but why 24m piles. I'd like to know if anyone can clarify. Or perhaps the worry was more of the house sliding on the hillside. Is it steep?
