StevenM Posted October 15, 2022 Posted October 15, 2022 Hi all, what is required under a suspended timber floor for an extension? Is this over site? Reading online I think over site is hardcore, sand blinding and then concrete. I am a complete novice and I am trying to project manage my extension. I think I may need to sack the builder and start taking a more hands on approach as the work is not to standard
SimonD Posted October 15, 2022 Posted October 15, 2022 You don't need hardcore, sand blinding and then concrete. All you need is a sufficient cover of inert material so a good spread of hardcore or a lean mix of concrete cover - 50mm concrete should be sufficient. Then just make sure you've got a min 150mm distance between the bottom of your joists and finished level of oversite. 1
StevenM Posted October 16, 2022 Author Posted October 16, 2022 On 15/10/2022 at 14:49, SimonD said: You don't need hardcore, sand blinding and then concrete. All you need is a sufficient cover of inert material so a good spread of hardcore or a lean mix of concrete cover - 50mm concrete should be sufficient. Then just make sure you've got a min 150mm distance between the bottom of your joists and finished level of oversite. I presume soil is not allowed.
Nickfromwales Posted October 17, 2022 Posted October 17, 2022 10 hours ago, StevenM said: I presume soil is not allowed. It’s what is under 100’s of 1000’s of floors, but not ideal tbh on a ‘new’ job. Some sort of water / vermin barrier is recommended, such as the 50mm of concrete cap. You can get a concrete lorry to deliver this ready mixed and just have 2 barrows to relay it from street to site. The lorry will need to be ordered to allow for the wait time for you to hand-ball it in, unless you can get it poured straight in and then just rake it around?
