jack1962 Posted September 23, 2022 Posted September 23, 2022 I am tiling my roof, it is a cross gable roof ,, T shaped. Are there Ridge tiles specially made for the intersection where both roofs meet? 1
Simplysimon Posted September 23, 2022 Posted September 23, 2022 48 minutes ago, jack1962 said: I am tiling my roof, it is a cross gable roof ,, T shaped. Are there Ridge tiles specially made for the intersection where both roofs meet? angle grinder and cut to shape
jack1962 Posted September 23, 2022 Author Posted September 23, 2022 21 minutes ago, Simplysimon said: angle grinder and cut to shape It is a dry ridge system, are you aware if there are ridge tiles shaped for the junction, i know they do them for hips where they meet the ridge
Simplysimon Posted September 23, 2022 Posted September 23, 2022 'fraid not, angle grinder, 7mm drill and a long screw at the end cut to shape with some foam and/or stainless mesh to stop anything getting in at the cut.
joe90 Posted September 23, 2022 Posted September 23, 2022 (edited) 2 hours ago, jack1962 said: It is a dry ridge system, Ask the supplier! (But I doubt it). Edited September 23, 2022 by joe90
Gone West Posted September 24, 2022 Posted September 24, 2022 15 hours ago, jack1962 said: Are there Ridge tiles specially made for the intersection where both roofs meet? Marley manufacture a dry hip system which uses cover pieces for the hip to ridge joins. I bought them for our last build and they may be suitable for your situation. https://www.marley.co.uk/accessories/dry-hip-system 1
joe90 Posted September 24, 2022 Posted September 24, 2022 55 minutes ago, Gone West said: Marley manufacture a dry hip system which uses cover pieces for the hip to ridge joins. I bought them for our last build and they may be suitable for your situation. https://www.marley.co.uk/accessories/dry-hip-system Interesting but not all roofs are at the same angle surely 🤔
jack1962 Posted September 24, 2022 Author Posted September 24, 2022 42 minutes ago, joe90 said: Interesting but not all roofs are at the same angle surely 🤔 Thanks Joe, i saw those,guess i will phone marley on Monday. The pitches on my roof are, main 45 deg, intersecting 51deg 15 hours ago, Simplysimon said: 'fraid not, angle grinder, 7mm drill and a long screw at the end cut to shape with some foam and/or stainless mesh to stop anything getting in at the cut. Thanks Simon.All those fancy systems and there is not a ridge tile for cross gable roof,, simple T Shape ridge tile...
joe90 Posted September 24, 2022 Posted September 24, 2022 1 hour ago, jack1962 said: simple T Shape ridge tile... BUT 2 hours ago, joe90 said: not all roofs are at the same angle 🤷♂️
Gone West Posted September 24, 2022 Posted September 24, 2022 2 hours ago, joe90 said: Interesting but not all roofs are at the same angle surely 🤔 IIRC they do three sizes which cover a range of angles. 1
jack1962 Posted September 24, 2022 Author Posted September 24, 2022 2 hours ago, Gone West said: IIRC they do three sizes which cover a range of angles. you are right they are not all the same angle. The ridge tiles i have cover pitches from approx 2? to 50 deg
Gone West Posted September 24, 2022 Posted September 24, 2022 1 hour ago, jack1962 said: The ridge tiles i have cover pitches from approx 2? to 50 deg Unfortunately the maximum roof pitch is 45 degrees with the Marley system.
5yearshed Posted January 19 Posted January 19 I have exactly the same cross gable same height ridge title problem. I can't believe this is so uncommon and arrangement that there isn't a product for it a simple t shaped ridge title like they have for ridge to hip but seems not!
