For those who have recently taken out a self build mortgage, what are the typical interest rates that you're seeing from lenders?
I appreciate everyone's circumstance and finances can vary, but I would hope to see some sort of common theme when it comes to the interest rates.
Thanks.
Yes I believe you are going to be looking at 4.8%+ and if the BoE rate increases as expected then it will get even more expensive. Also make sure you check out the fees.
I think most(/all?) are variable rate
Edited by Water
