jfb Posted September 15, 2022 Share Posted September 15, 2022 (edited) I remember reading elsewhere that a blending valve is needed (best practise) for the UFH manifold in an ASHP setup (might have been you saying it Peter!) My set up is Ecodan PUZ-WM 6kw ASHP, pre-plumbed cylinder with FTC6 controller. UFH heating in one zone downstairs and large rads upstairs as a second zone. No buffer tank, low loss header included on the cylinder. I bought an UFH package that includes a blending valve for the manifold. My plumber started work today on the install and he said that no blending valve is needed as the pre plumbed cylinder does all the modulating down to the desired temperature. Is he right? Edited September 15, 2022 by jfb Link to comment Share on other sites More sharing options...
ProDave Posted September 15, 2022 Share Posted September 15, 2022 I would insist your plumber fits the blending valve. Your radiator circuit will almost certainly want a higher temperature than the UFH and there is no way the ASHP even with it's tank can produce 2 feeds at the same time at different temperatures. Link to comment Share on other sites More sharing options...
jfb Posted September 15, 2022 Author Share Posted September 15, 2022 14 minutes ago, ProDave said: Your radiator circuit will almost certainly want a higher temperature than the UFH and there is no way the ASHP even with it's tank can produce 2 feeds at the same time at different temperatures. I can see the logic of this, thanks I had originally been hoping to do without rads upstairs as it should be well insulated/airtight but went with them to conform to spec needed for any hope of getting the grant available. I had been thinking that I might get away with just one temperature for UFH and rads as well (they are oversized) but maybe I am delusional about that! I'll speak with plumber and see what he has to say. Link to comment Share on other sites More sharing options...
JohnMo Posted September 15, 2022 Share Posted September 15, 2022 Our UFH flow temp is around 27, not sure if huge rads would like that low a temperature. Link to comment Share on other sites More sharing options...
