Hi, was wondering if anyone can give me a bit of help understanding the flow rates required to run my UFH.
I have the below info left with by the previous owner of the house ( we moved in a few months ago and just trying to get my head round everything ) detailing the loops and the return valve settings. I thought I was the flow meters that you adjust not the return valves? I tried to set the flow meters to match the table but I cannot get those settings. Not sure if it’s a pump issue or if these settings are way off?
what should the flow meters be set at? I know that’s a little hard to say as heat output & hear loss calcs would need to be done I presume?
6 minutes ago, JohnMo said:
Do you have a photo of what you were adjusting?
The flow meters at the top - screwing then in or out to get the flow rates. The table has return valve settings on it. Bit confusing when I thought it was just flow settings you can adjust.
this photo wasnt taken today. I turned on all the loops and tried to adjust them as per the table starting with the furthest away loop.
Edited by David-1712
47 minutes ago, jayc89 said:
Where did you get those return valve settings and are they in litres per minute?
They were left in a drawer along with all the other info for everything in the house. We moved into this house a few months ago. What other flow rate would they be in?
