marshian Posted January 2, 2025 Posted January 2, 2025 35 minutes ago, SteamyTea said: What base temperature did you use for your HDDs? 16.5 is my base - slightly higher than the normal 15.5 but the HDD site has a regression tool that I used to establish it after the last round of improvements and I’m pretty happy with the base line You have to bear in mind it’s a stupid shape house with a lot of rooms having 3 external walls which means it’s not a std box with two levels
SteamyTea Posted January 2, 2025 Posted January 2, 2025 22 minutes ago, marshian said: regression tool When I get some time, I shall see what I can match to my data. 23 minutes ago, marshian said: a stupid shape house Most houses are, They should really be domes. Stick them on a turntable and they can track the sun, or untrack the sun, depending on seasons.
marshian Posted January 2, 2025 Posted January 2, 2025 37 minutes ago, SteamyTea said: When I get some time, I shall see what I can match to my data. Regression tool is on this site - dead easy to use if you have data in xls or similar table format https://www.degreedays.net Only caveat is do your best to exclude HW energy usage or you'll get a funny answer (ie a lot more than your true baseline temp) 37 minutes ago, SteamyTea said: Most houses are, They should really be domes. Stick them on a turntable and they can track the sun, or untrack the sun, depending on seasons. Eskimos had the right idea then
DamonHD Posted February 22, 2025 Author Posted February 22, 2025 With the final fiddling of the bypass valve setting, I think that the heat pump system can be regarded as 'working' and forgettable: https://www.earth.org.uk/heat-pump-16WW-control.html#2025-02-10 So, just the time to rip apart the DHW side to start to put back the heat battery! https://www.earth.org.uk/reconnecting-the-16WW-heat-battery.html 1
