Hi all
I need to make a ceiling height 'cupboard' for UVC, expansion tanks, pump, valves etc. The other side will be utility worktop. Plan to use a sheet of MDF, but undecided on the spec. It wil be supported at ground and ceiling level and up to 900mm high by the the units that adjoin to it.
Trying to decide between 18 and 25mm thick, and if moisture resistant is worthwhile, or something more exotic like external grade or Medite Tricoya Extreme?
Any thoughts or recommendations folks?
Thanks
18mm is more than enough and moisture resistant for peace of mind. Also in case of leaks, seal all the edges with paint or varnish etc prior to fitting (paint the sides after).
Also worth looking at some of the 2 pack fillers from Ronseal and the like - a quick smear over any cut surface then sanding leaves it square and clean for paint and also stops water ingress
