Fraser Howat Posted August 27, 2022 Posted August 27, 2022 Hi Folks, Love this Forum, finally took the plunge and registered. I'm a keen DIY'r and ex-electrical engineer. Looking for some help, I've never done any sort of brickwork. My son recently ran his car into the front of the house (didn't realise it was in gear), see photo. The 4 bricks need replaced and there is a hairline crack in the mortar shown by the orange line. There is no other damage to the wall as far as I can tell. My plan is to use a grinder and chisel to take out the 4 bricks and the grinder again to cut out the mortar which is cracked then replace the bricks and mortar. My question is as the bricks being replaced run into the door opening will this be stable enough when cut out or am I in danger of causing more damage? My other idea was to replace Brick 1 first, let it dry completely then work on the rest. As I say no Brickie so any advice gratefully received. Cheers Fraser Bricks.pdf
Mr Punter Posted August 27, 2022 Posted August 27, 2022 The mortar colour is important here. Do a test and leave it a week to make sure it matches. Just take out the damaged bricks and the mortar joins. It will take a while but it won't make anything unstable.
Bonner Posted August 27, 2022 Posted August 27, 2022 Since it’s on a corner, I would replace brick 1 first as you suggest.
Fraser Howat Posted August 27, 2022 Author Posted August 27, 2022 Thanks both, I'll replace brick 1 and that will allow me to see the mortar match.
Canski Posted August 27, 2022 Posted August 27, 2022 I’m a Brickie and would also remove brick one and half of brick 2 replace brick 1 then the others all in one go. I use one of these. 1
