Radio 4: solar panels aren't designed for this temperature ....
ToughButterCup
Yes it's true. The output drops with high temperatures. There's a characteristic in the panel spec called NOCT, typically about -05% per degree C increase. If  the module is at 55C (quite likely in these conditions, the output will be reduced by about 15%.
However it's not particularly important as a midsummer day with near constant sun is going to generate more energy than a cool cloudy day.
Edited by billt
Clarification
And the solar intensity may be 20% higher than normal.
