ToughButterCup Posted July 18, 2022 Share Posted July 18, 2022 Evan Davies has just said that PV panels don't work as well at this temperature. Is that true ? Mine have been going full-on since this morning 9kWh so far (3.84 kWp, south facing) Link to comment Share on other sites More sharing options...
HerbJ Posted July 18, 2022 Share Posted July 18, 2022 Mine too - 6.5-year-old system3.99kWp (facing due just slightly west of due south) producing 16.9 kWh up to 1700hr, with a peak at 2.9kW Link to comment Share on other sites More sharing options...
billt Posted July 18, 2022 Share Posted July 18, 2022 (edited) Yes it's true. The output drops with high temperatures. There's a characteristic in the panel spec called NOCT, typically about -05% per degree C increase. If the module is at 55C (quite likely in these conditions, the output will be reduced by about 15%. However it's not particularly important as a midsummer day with near constant sun is going to generate more energy than a cool cloudy day. Edited July 18, 2022 by billt Clarification 1 Link to comment Share on other sites More sharing options...
JohnMo Posted July 18, 2022 Share Posted July 18, 2022 Normal chuff, by ill informed broadcasters. Tell you part of a story, as it sounds more dramatic. Link to comment Share on other sites More sharing options...
SteamyTea Posted July 18, 2022 Share Posted July 18, 2022 30 minutes ago, billt said: However it's not particularly important as a midsummer day with near constant sun is going to generate more energy than a cool cloudy day. And the solar intensity may be 20% higher than normal. Link to comment Share on other sites More sharing options...
