WWilts Posted July 15, 2022 Posted July 15, 2022 Are there any Building Regs requirements for space around a toilet?
markc Posted July 15, 2022 Posted July 15, 2022 Basins Height: Between 760 and 1190mm is comfortable for the majority of adults. Span (the distance from left to right, without obstructions): Recommended: 1020mm Required: 760mm Clearance to the front: Recommended: 760mm Required: 510mm Baths Height: Between 500 and 600mm is comfortable for the majority of adults. Space requirement: The minimum size for a straight bath is 1500 x 700mm. Clearance to the side: Recommended: 760mm Required: 530mm Taps, fillers, wastes and any other form of controls need to be accessible from both inside and outside the tub. Showers Space requirement: The minimum shower size is 760 x 760 mm. Clearance to the front: Recommended: 760mm Required: 610mm 1
Russell griffiths Posted July 15, 2022 Posted July 15, 2022 Only if it is your designated disabled access toilet. 1
