Energie thermodynamic system anyone have experience
Calw
I have the chance to purchase a full 300l system brand new unused for 800
Struggle to find information on them I was looking at ashp boilers but as it's only for my dhw this system might work out far cheaper
Info from users of SAHP's is a bit thin, not easy to get anyone to talk.  They are either rubbish or the best thing ever.  None of the data sheets, comply with the norms of a heat pump, so very little info there either.
I am not expecting it to generate all my hot water for free or cut my bills by 70% but if it was around 50% of my current DHW costs it would defo be worth it
Just looked at the datasheet, the average electric consumption is stated as 550W, the data sheet says it has a 7 hour charging time to heat cylinder.
0.55 x 7 = 3.85kWh per day
300L of water to heat from 30 to 55, requires 8.73kWh - so a CoP of 2.7.  Direct immersion heating would cost 2.7 times more.  This assumes the water temp drops that low before charging, if it only goes to 40 it only needs 5.24kWh, so CoP drops to 1.4.
Electric cost at £0.3/kWh, is £1.15 per day.
Gas at 0.0733 is (assuming 80% efficiency) is £0.77 per day.
Our DHW cylinder at is an old immersion
In summer it uses around 8kw to heat the water to 55c
8 x 0.27ppkw is £2.16 per day
In winter it varies  to around 13kw
13 x 0.27ppkw is £3.51 per day
But with electricity looking like increasing by 54% thouse figure will be more like
8 x 0.41ppkw is £3.20 per day
13 x 0.41ppkw is £5.33per day
So assuming a CoP of 2.7
It should be around
Summer would be 1.21 per day
Winter would be 1.97 per day
CoP at 1.4
Summer would be 2.34 per day
Winter would be 3.80 per day
Based on just cop
Looks to be a significant saving based on the figures on paper and current electric costs
I have just had a quick look at my DHW usage since May 22nd, when I changed over to using just the top element in my 200 lt cylinder.
2.3 kWh/day.
Prior to that it was 2.75 kWh/day.
I am not sure if, for a saving of ~0.5 kWh/day, which is 10p, only having 'just enough' DHW is worth it.
2.3 kWh/day.
Only 2.75kw a day seems low for 200litres...
200litres a day from 15c to 55c should take 9.3kw
200litres a day from 25c to 55c should take 6.99kw
On the face of it, it does seem low.
But.
DHW below about 30°C is of little use, and above 40°C it too hot.
As I use just the top part of the cylinder, there is only around 60 lt heated.  As that is about 50°C, that is only 15 to 20 °C uplift.
60 [kg] x 17.5 [°C] x 4.2 [SHC] = 4.41 MJ = 1.225 kWh.
So pretty close.
  • 4 months later...
Reading all thieve threads, people are working out the cost of the electric of using the immersion. I thought the use of the immersion was only to complement the thermodynamic panel operation, or is it that this really isn’t as good as they say?
