Trench foundation width
DannyG
Hi all
Our proposed build has 400mm wide masonry walls (200mm cavity) but I've just received the plans back from our structural engineer and he's specified just 450mm wide foundations in some places. This seems like a very tight tolerance to me and would need to be dug very accurately, is this normal? I was expecting 700mm all round.
We're on clay down as far as we checked (15m).
Thanks
Dan
There is a minimum of 50mm on each side (so wall thickness + 2 x 50mm = 500mm)
The SE's width will be based on loading and [assumed if no GI available] ground conditions. Going wider is no problem.
My walls are 380mm, I went with 600mm and that’s still a bit tight, so I would go with at least 600mm, 450 with 400 walls would be a nightmare.
I was lucky in that I only needed to go 700mm deep as on sand and gravel.
