13 minutes ago, PeterStarck said:
That's for a twin cell SAPV I think. They were talking about having SAPV with different numbers of cells. Presumably if they produced a single cell SAPV it would be cheaper, but would a single cell system work effectively?
I think the problem with a single cell unit (as mentioned earlier) might be the heat exchanger capacity.  The cells are in parallel in the Sunamp PV, which gives a maximum power output that's around the same as many combi boilers.  A single cell would be half the maximum power as well as half the capacity, I think.  I also suspect that the cells aren't where a lot of the money is within the unit.
4 minutes ago, Nickfromwales said:
Another major factor here will be how often the room is used. Will it be occupied ? Eg oldest brat residing there etc ?
Oi! Brats end up choosing our Old Folks Homes. Be nice to them (in public anyway)
You still haven't told me why you want an electric shower ;) ?!?
Small vented cylinder with a 3kW electric heater in it.
Cures the electrical supply problem and the storage problem.  Pretty cheap to fit too.
Does take up a bit more room, but may be it could be installed outside.
I think plumbing is way to complicated.  You either store water and heat it, or heat it on the fly.  Good job we don't get a plumber in to make the tea, it would never happen ;)
Good job your not in research and development Nick, or the SAPV would never have been invented :D :P
Just finished my tea, made in record breaking time ha ha. ?
