Barney12 Posted May 31, 2016 Posted May 31, 2016 So my PV install (when eventually finished) will have three separate arrays. Each one going to a distinct consumer unit (House, Workshop, Outbuilding). All these CU are fed from one DNO via SP&N switches. So...............Do I need a generation meter for each array OR can I connect the generation meter between the SP&N's and the DNO Meter?
ProDave Posted May 31, 2016 Posted May 31, 2016 Sounds to me like you will need 3 seperate meters, and quite possibly 3 seperate FIT accounts, unless your chosen supplier can deal with one account and 3 readings.
Barney12 Posted May 31, 2016 Author Posted May 31, 2016 5 hours ago, ProDave said: Sounds to me like you will need 3 seperate meters, and quite possibly 3 seperate FIT accounts, unless your chosen supplier can deal with one account and 3 readings. I thought that would be the case. It's not going to be a FiT install so the meters are mainly for self interest
SteamyTea Posted May 31, 2016 Posted May 31, 2016 (edited) If you are not too bothered by the accuracy, you could use current clamps and an appropriate reader/logger. The ones I use allow 9 clamps to be wirelessly connected. It will give you a good enough idea about what is happening. Edited May 31, 2016 by SteamyTea
