lstevensuk Posted May 16, 2022 Posted May 16, 2022 Hi - Just had my specs for for the block and beam floor, and looks they are proposing I cut the beams into the existing wall on the left. That looks like quite a bit of work to me cutting 9 x holes? Would I be better digging a test hole find my existing foundations and see If I can fit a single block wall and sit the beams on that? Thanks!
nod Posted May 16, 2022 Posted May 16, 2022 It’s unlikely that BC would let you sit another row of block on the existing foundation's As there wouldn’t be enough width You would have to put another strip of concrete parallel to the existing
bassanclan Posted May 16, 2022 Posted May 16, 2022 Not a massive amount of work to make ,9 pockets in a wall. An sds drill and a couple of hours work at most
lstevensuk Posted May 16, 2022 Author Posted May 16, 2022 (edited) 1 hour ago, bassanclan said: Not a massive amount of work to make ,9 pockets in a wall. An sds drill and a couple of hours work at most Great thank you, I'll go with that Edited May 16, 2022 by lstevensuk
Mr Punter Posted May 16, 2022 Posted May 16, 2022 4 hours ago, bassanclan said: Not a massive amount of work to make ,9 pockets in a wall. An sds drill and a couple of hours work at most I doubt it. What a pain to do. You need them all in nice and flat and level and smooth. I have just cut out for a couple of padstones on an existing wall and that took a while to stitch drill. Can't you have a ground bearing slab?
bassanclan Posted May 16, 2022 Posted May 16, 2022 Its a hell of a lot quicker to knock out a few bricks than have to build a whole new wall!
