Andeh Posted May 13, 2022 Posted May 13, 2022 We are going for internal bricks walls in our bungalow, and have some very tall ceilings. This means some of the room walls, will be approx 3.5m tall floor to ceiling and will be single 100mm block thick. At worst they are 3m wide before they hit a corner or equiv bracing structure, all dot & dabbed with Plasterboard Struc Eng has stipulated they are all tied into the ceiling every 1.2m with steel braces. He has also recommended they are not left unbraced pre-roof due to wind loads. I am no builder or structural engineer & ignore experts at my peril.....but I cant help but feel thats a tall & narrow wall. Am i over thinking this?!
Temp Posted May 13, 2022 Posted May 13, 2022 I think you are OK... Approved Document A.. https://www.gov.uk/government/publications/structure-approved-document-a I think you want Section 2C from page 13. Paragraph 2C10 on page 14 says minimum thickness for an internal load bearing wall is.. Quote ("Specified thickness from table 3"/2) -5mm Table 3 line 1 appears to give a figure of 190mm for a wall 3.5m high and upto 12m long. (190/2)-5 = 90mm So 100mm block should be OK. If the wall is less than 9m long it appears it can be up to 9m tall before you need to make it thicker (Table 3 line 2). 1
Andeh Posted May 15, 2022 Author Posted May 15, 2022 Really grateful Temp, thank you! Have had a look myself and feel better.
Conor Posted May 15, 2022 Posted May 15, 2022 It is scary how tall a single skin block wall can be. I questioned our main spine walls (7m, 4m long) a few times with architect and SE and they said it's fine.
Declan52 Posted May 15, 2022 Posted May 15, 2022 The main issue will be keeping them upright if there is any strong wind. A single skin wall 3.5m high will wobble. It's going to need braced at some point. My wall in my hall is over 5m high and it was a tad scary at the top. It wasn't until I got the roof on and used wall plate straps that it felt solid. Overnight I used scaffold planks with a few block on them and using a combination of kwikstage and trestles it managed to keep it from falling.
Andeh Posted May 15, 2022 Author Posted May 15, 2022 Thanks very much guys! Yeah, as it goes up the thought of "I'm sure if I pushed hard enough i could have it over' crossed my mind. I imagine sheer weight & then strapped at the top prevents the 'angle rise' of a block required for it to then go over once built. S. E. has recommended temp bracing in case of winds.
