MikeSharp01 Posted May 7, 2022 Posted May 7, 2022 We are reaching the crunch choices around the automation for the house and we have both Z-wave and Zigbee actuators / lighting. So I am casting about for a non cloud based hub I can use that handles both. Hubitat looks like a goer but there is / was also Wink not sure if that is still a thing though. Anybody used the Hubitat elevation hub?
Adam2 Posted May 12, 2022 Posted May 12, 2022 On 07/05/2022 at 21:34, MikeSharp01 said: Anybody used the Hubitat elevation hub? Expand I am. I was using Fibaro hub but did not like the programming/design side and much refer Hubitat. My plans are 4 x hubs with 1 per floor as we have a lot of concrete walls and floors. Just about to setup a slave type arrangement to test that out - will be doing it for real in 4 weeks so figured would experiment now with less stress! The online community seems pretty good also.
MikeSharp01 Posted May 12, 2022 Author Posted May 12, 2022 On 12/05/2022 at 18:14, Adam2 said: I am. I was using Fibaro hub but did not like the programming/design side and much refer Hubitat. My plans are 4 x hubs with 1 per floor as we have a lot of concrete walls and floors. Just about to setup a slave type arrangement to test that out - will be doing it for real in 4 weeks so figured would experiment now with less stress! Expand Interesting - I am still reading about it. I can see the community is strong. I need to understand the API possibilities. We have a small timber framed build and I was hoping that I would only need one and let the mesh do the rest. Lots to learn but thanks for the reassurance.
Adam2 Posted May 12, 2022 Posted May 12, 2022 I didn't do any detailed analysis of options really just liked the price and community and the multi hub option due to the house structure and size. Probably fine with a timber build. Always have the option to add hubs if needed. There is an antenna mod if you like that kind of fun but I'll try and go without that. @pocster getting on ok with that? Any issues?
Pocster Posted May 12, 2022 Posted May 12, 2022 On 12/05/2022 at 19:56, Adam2 said: I didn't do any detailed analysis of options really just liked the price and community and the multi hub option due to the house structure and size. Probably fine with a timber build. Always have the option to add hubs if needed. There is an antenna mod if you like that kind of fun but I'll try and go without that. @pocster getting on ok with that? Any issues? Expand Not much you can’t do with HomeSeer - but it has its quirks . Before tried fibaro server , Mac stuff and a few others . HomeSeer has a really active forum so there’s loads of support
Pocster Posted May 12, 2022 Posted May 12, 2022 On 12/05/2022 at 20:27, pocster said: Not much you can’t do with HomeSeer - but it has its quirks . Before tried fibaro server , Mac stuff and a few others . HomeSeer has a really active forum so there’s loads of support Expand Think there’s a free 1 month trial - so worth a shot on pc or pi
Wil Posted May 13, 2022 Posted May 13, 2022 I use a Homey, but am also experimenting with Home Assistant for the heating. Homey to be fair has been fairly foolproof for several years now.
