Glue insulation PIR to concrete slab?
ashthekid
59 minutes ago, ashthekid said:
Somebody has recommended I glue down, with cheap tile adhesive, the 100mm celotex insulation I intend to use before plastic vapour membrane layer, UFH and liquid screed.
Has anyone ever done this before?
I can see the logic, as 50mm of LS has little weight per m2. One assumes they refer to the non foil-backed PIR?
Edited by Nickfromwales
1 hour ago, ashthekid said:
Plastic knock ins?
Yes
A plastic stem with a 50 mil head
10 mil hole and a couple of taps with a hammer 2 minutes per sheet
Readyfix sell them
2 hours ago, ashthekid said:
And they screwed into the concrete easily?
Just drill a hole, push them in and then tap in the centre rod and it spreads out and grips like a wall plug
