Moggaman Posted April 26, 2022 Posted April 26, 2022 Hi all. Does a quooker just need a normal electrical socket in terms of electricity.. Also , is the standard 50mm white pipe ok for boiling water? thanks
PeterW Posted April 26, 2022 Posted April 26, 2022 Yes although some models need a fused spur No you need to use stuff that is suitable for boiling water discharge
Moggaman Posted April 26, 2022 Author Posted April 26, 2022 19 minutes ago, PeterW said: Yes although some models need a fused spur No you need to use stuff that is suitable for boiling water discharge Can a fused spur be hidden behind kitchen?.. I have kitchen first fix wired and only a double socket to work with. Also, the waste pipe out is a standard 50mm white pipe.. what can I do in that case…I imagine using the white one would not be a huge risk? thanks
nod Posted April 27, 2022 Posted April 27, 2022 I have d socket and a fuse spare In the sink cupboard next to the boiling water tank
MikeSharp01 Posted April 27, 2022 Posted April 27, 2022 7 hours ago, Moggaman said: Can a fused spur be hidden behind kitchen?.. I have kitchen first fix wired and only a double socket to work with. If you have a double socket on a ring then a competent electrician can add a switch fused spur to that and you could have that fitted inside the cupboard close to the device with appropriate cable run and protection for the cable, if needed, back to the double socket.
