Does the protrusion of a door knob/handle on a bedroom door affect the regulation clear opening width when the door opens against a wall only 90 degrees?
It is a pet hate of mine to only have a door that opens 90 degrees.
design it out, you need a minimum 125mm nin on the hinge side, this allows the door to swing and to put a decent gap between architrave and adjoining wall.
I've got 115mm from hinge to wall so the door goes a tad beyond 90.
Constrained by both a 150 yr old building and full building regs, whole project is a car crash in design terms. Just glad if I can get sign off any which way!
Why the hate?
Why the hate?
Because you catch yourself on the handle as you flit about.
