Crofter Posted May 22, 2024 Posted May 22, 2024 I don't think CT1 would work very well. It's got quite good bond strength when used over large areas, but it won't soak in and expand in to every little nook and cranny like PU glue will. I'm not up to date with prices but I've never considered CT1 to be particularly cheap either...
Jenki Posted May 22, 2024 Posted May 22, 2024 (edited) Expanding PU glue all the way. And loads of it. All edges, even cut edges, and joists. Depending on the set time I also use ratchet straps to squeeze the joints tight. Once dry the glue can be scraped of the floor where it has oozed from the joints. I used egger protect on my projects, with their own glue and you get a solid, water proof, hard surface floor. Rolls Royce solution. The glue expands and fills any unevenness and you end up with a flatter floor, solid and no squeaks, now or in the future. Edited May 22, 2024 by Jenki Typo 1 1
