April 14, 20224 yr I am considering EWI for a large gable end on Victorian terrace. My choice of render would have been lime-based for breathability if I was doing directly onto the brick. I’ve been offered EWI with silicone render and wondering if it matters what render I use on the outer coat if I have EWI in place? thanks
April 14, 20224 yr K Rend do a suitable render for EWI The advantage over the others is that it doesn’t need a separate scratch coat and it’s also breathable
April 14, 20224 yr 7 hours ago, Bex said: I am considering EWI for a large gable end on Victorian terrace. My choice of render would have been lime-based for breathability if I was doing directly onto the brick. I’ve been offered EWI with silicone render and wondering if it matters what render I use on the outer coat if I have EWI in place? thanks Breathability is much less of an issue with EWI as the wall never gets cold and if the EWI is detailed well will be quite dry.
April 14, 20224 yr Author 1 hour ago, Conor said: Is the insulation EPS? We went for a renderer that used Sto. It's fantastic. Polystyrene boards
