Jordan1 Posted April 13, 2022 Share Posted April 13, 2022 Hi All Does anyone have any alternatives to kingspan that can provide psi values for a 100mm brick-100mm cavity (with 50mm insulation board) and 100 mm dense concrete block? I was first looking at QUINN/MANNOK as its about half the price, have all the relevant details except for psi values when using a 50mm insulation board. Essentially what I'm looking for is similar to the attached with a cheaper product so wondered if anyone had had any luck with this Thanks Jordan 1581676158_50mmCavityKoolthermK108(50mmin100mmcavity)StandardDetails-2ndIssueFebruary2019.pdf Link to comment Share on other sites More sharing options...
MikeGrahamT21 Posted April 14, 2022 Share Posted April 14, 2022 Kooltherm is Phenolic, I don't know of any other manufacturers that do this type insulation, others are PIR. Take a look on seconds and co, you may get some cheaper on here with a few knocks to it, or a few mm out. Link to comment Share on other sites More sharing options...
Iceverge Posted April 14, 2022 Share Posted April 14, 2022 21 hours ago, Jordan1 said: Hi All Does anyone have any alternatives to kingspan that can provide psi values for a 100mm brick-100mm cavity (with 50mm insulation board) and 100 mm dense concrete block? I was first looking at QUINN/MANNOK as its about half the price, have all the relevant details except for psi values when using a 50mm insulation board. Essentially what I'm looking for is similar to the attached with a cheaper product so wondered if anyone had had any luck with this Thanks Jordan 1581676158_50mmCavityKoolthermK108(50mmin100mmcavity)StandardDetails-2ndIssueFebruary2019.pdf 3.1 MB · 2 downloads Boards in the cavity isn't the best choice. Plenty if threads here if you search. Eps beads or full fill mineral wool are a more robust option along with standard 7N blocks. You'll need a wider cavity for the same U value however. Link to comment Share on other sites More sharing options...
