WWilts Posted April 3, 2022 Posted April 3, 2022 New build in progress. Roof covering: Roofshield air permeable membrane with Cambrian slate on top. Soffits well pinned down to outer leaf by wood/screws. Eaves have PIR insulation against inner leaf, crown wool insulation to spill out from loft into remaining eaves space. Is there any real reason to be siliconing the soffit/wall junction? (red arrow)
WWilts Posted April 3, 2022 Author Posted April 3, 2022 No need for ventilation with this air permeable roof membrane
saveasteading Posted April 4, 2022 Posted April 4, 2022 On 03/04/2022 at 13:05, WWilts said: any real reason to be siliconing the soffit/wall junction? If there is a gap, then insects will enter and live in the eaves. Bees and wasps mine into PIR. Whether that is good or bad is another discussion. 1
WWilts Posted April 4, 2022 Author Posted April 4, 2022 1 hour ago, saveasteading said: If there is a gap, then insects will enter and live in the eaves. Would a plastic soffit vent mesh do the job? (folded and inserted into the tiny gap) Or is multipurpose silicone better?
saveasteading Posted April 5, 2022 Posted April 5, 2022 For a few mm just silicone. A named one as it needs to be stand a lot of weather and uv, and you dont want to be doing that again. 1
Simplysimon Posted April 5, 2022 Posted April 5, 2022 On 03/04/2022 at 16:57, WWilts said: No need for ventilation with this air permeable roof membrane forgot you don't board roofs down there
