Looking at P5 boards and celotex instead of celotex and screed
Brian in Dorset
Following 3m ground floor extension and loft conversion i am looking to raise the height of existing concrete ground floor. (floorplan attached).
There are currently smallish differences in floor height between rooms and hall and a little bit of "out of level".
I have been looking at an increase of about 100-120mm and we increased downstairs wall height by a whole block.
I am considering 50mm celotex and 50mm flowing screed which will allow me a bit of tolerance with celotex levels etc.
I am now thinking about 80mm celotex and 22mm P5 boards.
is it possible for a competent DIYer to get a level enough surface on top of celotex to fit the boards and for the whole thing to be acceptable result?
Is there a foolproof way to sort out differences of level (maybe 3mm over metre) and level (maybe 0-15mm) between rooms.
The boards look increasingly tempting but i am worrying about the final result.
Any advice regarding boards and celotex appreciated.
Thanks
Brian
I have done a few floating floors with 22mm T&G chipboard over insulation and have not had any issues with bounce.  It weights about 16Kg per m2, so a 4m square room will be a quarter of a tonne.
It needs to be installed correctly - left in the room to acclimatise, 10mm expansion gap all round.  If you have tiles you could use a fibre cement type instead of chipboard.
