smart51 Posted March 20, 2022 Share Posted March 20, 2022 I must be reading this wrong. Thermalite Turbo aircrete blocks have a quoted insulation value of 0.11 W/m.K according to the data sheet. Part L for England (2022) calls for 0.16 for walls and 0.11 for floors. At face value, it suggests that a single skin of blocks is enough. What have I got wrong? Is it per metre thickness of Thermalite block, rather than for 1 block thickness? https://www.forterra.co.uk/wp-content/uploads/2021/02/Thermalite_A5_guide_2020.pdf Link to comment Share on other sites More sharing options...
PeterW Posted March 20, 2022 Share Posted March 20, 2022 Correct - it is per metre. 1 Link to comment Share on other sites More sharing options...
Russell griffiths Posted March 21, 2022 Share Posted March 21, 2022 And then it also depends on the mortar joints, they are nothing like as insulated as a block, so an as built wall does not add up to the stated value of a block, lots more things to add into the equation. Link to comment Share on other sites More sharing options...
JohnMo Posted March 21, 2022 Share Posted March 21, 2022 Completely different units. But part of a u value calc. W/m.k, that how much heat is lost per metre thickness of that material per degree. U value is W/m2.k that is what building control looks at, it is the build up of all materials in say a wall in area Link to comment Share on other sites More sharing options...
tonyshouse Posted March 21, 2022 Share Posted March 21, 2022 Not just the blocks, the cavity, cavity insulation,plaster, outside skin I stopped using aircrete in the 1980s as it cracks too easily Link to comment Share on other sites More sharing options...
smart51 Posted March 21, 2022 Author Share Posted March 21, 2022 4 hours ago, tonyshouse said: I stopped using aircrete in the 1980s as it cracks too easily In service or just during construction? Link to comment Share on other sites More sharing options...
tonyshouse Posted March 21, 2022 Share Posted March 21, 2022 Both especially irksome for new build snagging but the cracking is ongoing even from doors slamming thermal movements, jumping up and down some go unnoticed being behind dry lining causing additional air infiltration 1 Link to comment Share on other sites More sharing options...
