@ToughButterCup - can you help me understand the battery charging capabilities of the product? I’d like to charge at night (on e7) which I see in the manual there is a timed program for, but also have it charge from the PV in the day as normal.
The manual isn’t clear whether setting a timed charge program will stop it charging from PV?
For the benefit of the search, I reached out to the manufacturer who provided the following detail:
The priority for the inverter is set time charging > home use > excess solar power for battery charging. Therefore, the inverter charges the battery in the day time when there is more than enough solar power.
  • 11 months later...
On 28/02/2022 at 16:09, ToughButterCup said:
We have the 4G version. I've given up trying to get the web version of the performance data out of it - our MyEnergi hub sorts that out though....
How did you get the myenergi hub to show the solar?
i had Zappi installed with a myenergi hub but since having solar installed can’t seem to get all on 1 app and installer just gave me the solis app and doesn’t know how to connect the pair!
  • 2 months later...
56 minutes ago, eniacs said:
I've got one, whilst it works, it doesn't work as advertised. I'm looking at changing to a Sunsynk.
Would be good to hear why it doesn't work as advertised, always good to have a reference for this sort of thing.
