J1mbo Posted February 28, 2022 Share Posted February 28, 2022 Any concerns or experiences with this inverter please: Datasheet-Solis-RHI-3-6K-48ES-5G-EN.pdf (zerohomebills.com) Link to comment Share on other sites More sharing options...
ToughButterCup Posted February 28, 2022 Share Posted February 28, 2022 We have the 4G version. I've given up trying to get the web version of the performance data out of it - our MyEnergi hub sorts that out though.... Link to comment Share on other sites More sharing options...
J1mbo Posted February 28, 2022 Author Share Posted February 28, 2022 Thanks. I'm really interested in the backup power capability of the unit. Do you have batteries attached to it? Link to comment Share on other sites More sharing options...
J1mbo Posted March 10, 2022 Author Share Posted March 10, 2022 @ToughButterCup - can you help me understand the battery charging capabilities of the product? I’d like to charge at night (on e7) which I see in the manual there is a timed program for, but also have it charge from the PV in the day as normal. The manual isn’t clear whether setting a timed charge program will stop it charging from PV? Link to comment Share on other sites More sharing options...
J1mbo Posted March 12, 2022 Author Share Posted March 12, 2022 For the benefit of the search, I reached out to the manufacturer who provided the following detail: The priority for the inverter is set time charging > home use > excess solar power for battery charging. Therefore, the inverter charges the battery in the day time when there is more than enough solar power. Link to comment Share on other sites More sharing options...
Guppy Posted February 22, 2023 Share Posted February 22, 2023 On 28/02/2022 at 16:09, ToughButterCup said: We have the 4G version. I've given up trying to get the web version of the performance data out of it - our MyEnergi hub sorts that out though.... How did you get the myenergi hub to show the solar? i had Zappi installed with a myenergi hub but since having solar installed can’t seem to get all on 1 app and installer just gave me the solis app and doesn’t know how to connect the pair! Link to comment Share on other sites More sharing options...
eniacs Posted April 27, 2023 Share Posted April 27, 2023 I've got one, whilst it works, it doesn't work as advertised. I'm looking at changing to a Sunsynk. Link to comment Share on other sites More sharing options...
Carrerahill Posted April 27, 2023 Share Posted April 27, 2023 56 minutes ago, eniacs said: I've got one, whilst it works, it doesn't work as advertised. I'm looking at changing to a Sunsynk. Would be good to hear why it doesn't work as advertised, always good to have a reference for this sort of thing. Link to comment Share on other sites More sharing options...
eniacs Posted April 27, 2023 Share Posted April 27, 2023 Datasheet shows 5kw charge/discharge from battery. Inverter actually only does this for 15 mins, then drops to 3.6kw. Link to comment Share on other sites More sharing options...
