I am fitting a door handle to a door which comes with a 60mm "strong latch".  This means that once the latch will be fitted, the centre of the threaded mortice spindle bar on which the handle is mounted is 60mm from the edge of the door. I would like a mortice lock which once fitted will have a keyhole that is in line with the spindle bar. What size mortice lock do i need?
Very helpful this @Temp thank you. The trouble is I'm now trying to find a simple 2 lever mortice lock with a 60mm backset. Even upgrading to 3 lever doesn't open up many more choices.
So you're trying to use seperate latch and lock on same door? Can you switch the handle onto a combined unit?
Edited by Temp
Yeah, that’s probably going to be easier, just annoying because I spent a bit of money on Corston to get everything matching everything, to the extent that my latch plates match my sockets and switches and handles. But I’m a bit OCD like that.
So a standard 3 lever will be fine but your issue is 60mm is the euro standard that’s why you will struggle. If you go with 57mm then you have lots more options and you should be able to work with the 3mm difference
Thanks. What’s the standard size the other side of 60mm? Is there a 62mm or 63mm standard?
