Conalmcn Posted February 23, 2022 Share Posted February 23, 2022 Originally I had set my mind on using an grant vortex oil boiler but have decided to change to a ashp setup instead. House is a 270sq metres new build insulated to a fairly decent standard, it will be airtight and I have a mvhr system installed. I'm struggling to decide on which heatpump and cylinder setup to go with. Joule have carried out their assessment and recommended a 12kw samsung heat pump with a joule 250litre kodiak uvc. Has anyone used this setup before and if not what is a good alternative? I'm after value for money but not at the expense of reliability. Link to comment Share on other sites More sharing options...
SBMS Posted February 23, 2022 Share Posted February 23, 2022 Are you diy installing the ASHP or using an MCS accredited installer? Link to comment Share on other sites More sharing options...
JohnMo Posted February 23, 2022 Share Posted February 23, 2022 Do you know you home heat demand at the lowest temperature outdoors, that will be the main driver to size Link to comment Share on other sites More sharing options...
Conalmcn Posted February 23, 2022 Author Share Posted February 23, 2022 14 minutes ago, SBMS said: Are you diy installing the ASHP or using an MCS accredited installer? Will be carried out by a plumber/electrician but not mcs accredited most likely. Link to comment Share on other sites More sharing options...
Conalmcn Posted February 23, 2022 Author Share Posted February 23, 2022 Just now, JohnMo said: Do you know you home heat demand at the lowest temperature outdoors, that will be the main driver to size The size according to joule is 12kw so I'm basing any alternative system on that really. Just looking for other options or to see if the samsung/joule setup is good Link to comment Share on other sites More sharing options...
SBMS Posted February 23, 2022 Share Posted February 23, 2022 Consider an MCS certified. You can then get a £5k grant from the government Boiler Upgrade Scheme. We are having a Nibe f-2040 12kw, 300l cylinder, buffer, controls and all pipe work - 11k installed. Will cost us 6k. And the nibe isn’t cheap. Link to comment Share on other sites More sharing options...
Conalmcn Posted February 23, 2022 Author Share Posted February 23, 2022 1 minute ago, SBMS said: Consider an MCS certified. You can then get a £5k grant from the government Boiler Upgrade Scheme. We are having a Nibe f-2040 12kw, 300l cylinder, buffer, controls and all pipe work - 11k installed. Will cost us 6k. And the nibe isn’t cheap. Based in Ireland so any grants aren't available unfortunately Link to comment Share on other sites More sharing options...
SBMS Posted February 23, 2022 Share Posted February 23, 2022 1 minute ago, Conalmcn said: Based in Ireland so any grants aren't available unfortunately Ah, bad luck. My brother (small scale developer) swears by the Ecodan units as a great balance between price and performance. Link to comment Share on other sites More sharing options...
SuperJohnG Posted February 23, 2022 Share Posted February 23, 2022 56 minutes ago, SBMS said: Consider an MCS certified. You can then get a £5k grant from the government Boiler Upgrade Scheme. We are having a Nibe f-2040 12kw, 300l cylinder, buffer, controls and all pipe work - 11k installed. Will cost us 6k. And the nibe isn’t cheap. Seems reasonable at 6k installed including pipework. I have done my ufh already...I just need the rest and that seems attractive. Whereabouts are you? Link to comment Share on other sites More sharing options...
SBMS Posted February 23, 2022 Share Posted February 23, 2022 10 minutes ago, SuperJohnG said: Seems reasonable at 6k installed including pipework. I have done my ufh already...I just need the rest and that seems attractive. Whereabouts are you? Lancashire Link to comment Share on other sites More sharing options...
dave1967 Posted March 14, 2022 Share Posted March 14, 2022 I'm in Cheshire looking for installer for my new house. Do they cover my area? Thanks Link to comment Share on other sites More sharing options...
Christiano Posted March 15, 2022 Share Posted March 15, 2022 We were going to go with Joule/Samsung but changed to a different installer who gave us the same Samsung 16kW Heat Pump as offered by Joule. It’s working well, my main problem with it is the lack of remote-controlness. I think the Joule system came with an app but not via the alternative supplier. If you expect to be able to get lots of data from it or control it remotely, have a really close look at what you are getting. Back to the unit though, Samsung give a 7-year warranty (in the UK, subject to having it serviced, check it’s the same for you) and it’s been fine for us since installation in September last year. Link to comment Share on other sites More sharing options...
