I have a solid brick wall house with an open chimney in one of the downstairs rooms. Its not used but is uncapped. I want to do something with it to help reduce drafts but am worried about damp if I just brick it up.
What’s the best approach to take?
thanks
Just now, tonyshouse said:
Is it on an outside wall ?
It is, the north facing wall so arguably the worst from a damp perspective.
thanks
Surely its capped with a vent? Rather than open to the elements?
If its still open, cap it with a vent.
Then buy one off these: https://www.chimneysheep.co.uk/
In the summer if you fancy a bit of cooling, pull it out.
If it was mine I would take a birch out of the flue 500mm upon the loft, brick up bottom , pour eps beads in f Tom the loft up to the level of the appeture , cap and vent the top and hope it will be ok. I like lime pointing,makes all the difference
or I get an old pillow and put inside two black sacks and shove it up a bit
Its fitted with a cowl. We decided that made sense as soon as we found hailstone on the carpet last year
So there’s no problems from filling the opening and bricking up as long as the top is still open?
Technically and this is a throwback to the 1960’s it should be vented with an air brick, I am finding that it is ok to fill with insulation to above loft insulation level and vent from there up
works near 100%  with internal wall chimneys, external wall ones are more risky but I haven’t seen any problems and less likely to have them than with chimney balloons of which there are lots with no reported problems
vent the top and there will/should be an air brick in it as well near the bottom.
You can physically cap it to weather tight it ass long as you add a couple air bricks to the stack at the top.
Edited by Dave Jones
