Barryscotland Posted February 8, 2022 Posted February 8, 2022 I have my panels connected into inverter in attic with a DC isolator then AC out into an AC isolator, cable runs down to cupboard with consumer unit to another Isolator. Which side of that isolator would the generation meter go and where would it normally be connected into consumer unit?
Wil Posted February 8, 2022 Posted February 8, 2022 Generation meter immediately after the inverter (you didn't mention an inverter though, so how does it get from DC to AC?) on the AC side before it goes down to the CU. Or can sit next to the CU before it enters the breaker there so it's readable without going in the loft.
ProDave Posted February 8, 2022 Posted February 8, 2022 Generation meter in line with the cable coming down from the inverter and before the downstairs ac isolator. For a simple job like this, get a local electrician to decide where and how to connect it into the consumer unit. Or post a picture of your consumer unit with the cover off for suggestions.
