Moggaman Posted February 5, 2022 Posted February 5, 2022 Hi . In my self build I am wondering when is best to paint… I have block walls upstairs and down.skimmed upstairs , a mix downstairs… Should I paint before kitchen goes in or when is best? Before 2nd fix electric? thanks
tonyshouse Posted February 5, 2022 Posted February 5, 2022 Need to be sure that plaster has dried out before painting and even then best use non vinyl ie Supermat contract emulsion suitable for new plaster. I like paint before screwing up ot before fitting electrics, there will be some touching up, sweep up and hoover well before you start , pole sander with worn out sanding sheet before and between coats
Moggaman Posted February 6, 2022 Author Posted February 6, 2022 3 hours ago, tonyshouse said: Need to be sure that plaster has dried out before painting and even then best use non vinyl ie Supermat contract emulsion suitable for new plaster. I like paint before screwing up ot before fitting electrics, there will be some touching up, sweep up and hoover well before you start , pole sander with worn out sanding sheet before and between coats Thanks, how long before plaster drys out roughly ?…3 weeks
SteamyTea Posted February 6, 2022 Posted February 6, 2022 Do you know the relative humidity in the room/building. Would have thought that would be a good gauge to how dry the walls are.
JohnMo Posted February 6, 2022 Posted February 6, 2022 We did 3 coats, 2 costs prior to anything being installed. A finish coat after 1
tonyshouse Posted February 6, 2022 Posted February 6, 2022 Plaster drying out depends on ventilation to remove the moisture and temperature, so heating on windows open til no condensation on the windows in the morning when closed running your ventilation system will help a lot too
