GrantMcscott Posted January 27, 2022 Posted January 27, 2022 Getting UFH installed and then screed poured next week. Does it matter if there is small movement up and down between insulation boards 2 to 3mm. I have been going round putting blocks on them and foaming them together to stop it. The insulation is tight fitted but still some board still moving when you walk on them close to the joins Is it a concern or will the UFH pipes tighten it up and screed weigh it down? Thanks
JohnMo Posted January 27, 2022 Posted January 27, 2022 Need to fill all gaps, and tape them. The screed will weight it down. You don't want the screed to under the insulation or that's a world of pain. Prior to UFH heating pipes cover insulation with thin DPM and tape all joints.
GrantMcscott Posted January 27, 2022 Author Posted January 27, 2022 54 minutes ago, JohnMo said: Need to fill all gaps, and tape them. The screed will weight it down. You don't want the screed to under the insulation or that's a world of pain. Prior to UFH heating pipes cover insulation with thin DPM and tape all joints. Yes i have all the gaps filled with foam and joints taped will be laying DPM at weekend over the top thanks
Nickfromwales Posted January 27, 2022 Posted January 27, 2022 It needs to be a VERY thin membrane suitable for use with the liquid screed, so that it allows the screed to completely encompass the UFH pipe. Leave lots of slack / small folds in the membrane to allow it to be able to move and wrap as tightly as possible around the pipes. If you don’t leave this slack the membrane will tent over the pipes which you don’t want.
GrantMcscott Posted January 27, 2022 Author Posted January 27, 2022 14 minutes ago, Nickfromwales said: It needs to be a VERY thin membrane suitable for use with the liquid screed, so that it allows the screed to completely encompass the UFH pipe. Leave lots of slack / small folds in the membrane to allow it to be able to move and wrap as tightly as possible around the pipes. If you don’t leave this slack the membrane will tent over the pipes which you don’t want. Hi I got this membrane https://www.toolstation.com/green-vapour-barrier-125mu/p86538 Thanks
Nickfromwales Posted January 27, 2022 Posted January 27, 2022 12 minutes ago, GrantMcscott said: Hi I got this membrane https://www.toolstation.com/green-vapour-barrier-125mu/p86538 Thanks Too thick. 500 is the thickest I’d use tbh.
Nickfromwales Posted January 27, 2022 Posted January 27, 2022 Are the pipes down yet? If going under then you’re linked one is fine. Sorry. Just assumed this was going atop retrospectively for some daft reason. Been a long day.
GrantMcscott Posted January 27, 2022 Author Posted January 27, 2022 Just now, Nickfromwales said: Are the pipes down yet? If going under then you’re linked one is fine. Sorry. Just assumed this was going atop retrospectively for some daft reason. Been a long day. Hi, it is going on top of insulation bellow the pipes. Pipes get laid Monday
Nickfromwales Posted January 27, 2022 Posted January 27, 2022 Just now, GrantMcscott said: Hi, it is going on top of insulation bellow the pipes. Pipes get laid Monday Ah, ok. Then ignore my above rambling. I’ll get my coat.
