So the plastering of the first floor reveals around the stair hole can proceed, I have had to remove the temporary first floor corner posts and handrails.
The final stairs and handrail will not be fitted for a couple of weeks.  So what H&S protection can I put in place please?
Make an upside down U shape out of 50 x 100, stand it on the temporary stairs so the bottom of the U is about level with 1st floor  and then batten over the biggest drop area.
The remainder is safe because of the handrail and you should still have access by walking through the supports.
  • 5 weeks later...
46 minutes ago, John Poole said:
Stand pallets on their ends and join together.  fall protection and kick plate protection.
Job for the weekend .....
