Pocster Posted April 21, 2017 Share Posted April 21, 2017 Hey all im confused by these so they go in my outer leaf with 'weep' plugs either side so moisture can escape . why have I never seen these on a build before ? also if you render externally going to be very easy to block them even if you cover them . anyone else been 'told' to use them ? cheers Link to comment Share on other sites More sharing options...
Brickie Posted April 21, 2017 Share Posted April 21, 2017 Okay,a cavity tray will go from your inner leaf down to the outer leaf,with weep vents @900mm or 450mm centres as per spec. For rendered work they should be sat proud of the blockwork to the depth of the render (say 20mm,if 2 coat sand & cement) so they sit flush with the finish render. They are a common detail on cavity work,principally over lintels but also at g/f level if spec'd & also at any parapets or where adjacent structures abut (I.e. Garage roof.) Your TF supplier should supply you with a technical sheet showing how to install. Link to comment Share on other sites More sharing options...
Pocster Posted April 22, 2017 Author Share Posted April 22, 2017 Thanks it's been suggested I put trays the entire length of the block work below dpc . Not just around window details etc . Link to comment Share on other sites More sharing options...
Brickie Posted April 23, 2017 Share Posted April 23, 2017 Why below Dpc? Who has suggested this? Link to comment Share on other sites More sharing options...
Temp Posted April 23, 2017 Share Posted April 23, 2017 As I understand it cavity trays are intended to catch any water running down the inside of the outer leaf and divert it to the outside. The source of this water is rain penetrating the outer leaf (bricks are porous). However I though render was meant to be a waterproof barrier so do you need cavity trays at all if the outer leaf is rendered? Link to comment Share on other sites More sharing options...
Temp Posted April 23, 2017 Share Posted April 23, 2017 OK Google says with render you still need cavity trays but might not need weep holes... https://www.labcwarranty.co.uk/technical-library/weep-holes-in-rendered-cavity-walls/ Link to comment Share on other sites More sharing options...
Pocster Posted April 23, 2017 Author Share Posted April 23, 2017 (edited) 13 hours ago, Brickie said: Why below Dpc? Who has suggested this? Architect !!! but yes it confuses me why when you have render like k rend or similar Edited April 23, 2017 by pocster Link to comment Share on other sites More sharing options...
nod Posted April 23, 2017 Share Posted April 23, 2017 32 minutes ago, pocster said: Architect !!! but yes it confuses me why when you have render like k rend or similar Unlikely to get water soaking through K rend But you still need trays above all openings With at least a couple of weeps on each Ive just fully K rendered mine I set the weeps at 15 mil and rendered over them When I rubbed up the render the following morning the weeps reappeared I set all the weeps right above the heads and 150 out with a central weep for larger openings So I new were they were You really don't get much render going inside the weep I jus poke a fine nail in to clean them out The L shaped type are best for render as you are left with only 10 mil showing Link to comment Share on other sites More sharing options...
Brickie Posted April 24, 2017 Share Posted April 24, 2017 Have you got a drawing from the architect? Link to comment Share on other sites More sharing options...
Pocster Posted April 24, 2017 Author Share Posted April 24, 2017 (edited) 8 hours ago, Brickie said: Have you got a drawing from the architect? Now you are joking ! Nope!. Edited April 24, 2017 by pocster Link to comment Share on other sites More sharing options...
Brickie Posted April 24, 2017 Share Posted April 24, 2017 3 hours ago, pocster said: Now you are joking ! Nope!. Ok,so where does it say you need a Dpc tray below Dpc? The standard detail when I did them was a tray lapping down to Dpc level ( saves you using 100mm damp too,if you get it right.) Link to comment Share on other sites More sharing options...
Pocster Posted April 24, 2017 Author Share Posted April 24, 2017 Just now, Brickie said: Ok,so where does it say you need a Dpc tray below Dpc? The standard detail when I did them was a tray lapping down to Dpc level ( saves you using 100mm damp too,if you get it right.) Lol it doesn't ! . The architect visited the site and just said so . i get the impression everyone else gets every detail defined - I don't ! :-/ Link to comment Share on other sites More sharing options...
