  • 1 month later...
Thanks @ragg987 meter working great :-)
As a comparison I seal a calibrated (or so it says on box) cheap digital temperature and humidity meter in a plastic bag - gave approx the same reading:
What guys do up here is simply tape a bit of clear plastic over the floor. If you see any moisture under it, it's too wet to lay the flooring.
