Been offered a new Vaillant 425 which is described as an “open vent only boiler” I don’t think it is suitable but want to make sure before I turn it down an my plumber is awol till after new year so can’t ask him.
I need one to run an unvented cylinder and ufh
anyone no for sure if the “open vent only” bit means it needs to be supplied from a header tank etc n not suitable for our needs
Even if the boiler needs to be on a vented system fed by a header tank, that does not stop you having an unvented hot water tank.  The boiler circuit just heats the input coil and is not hydraulically connected to the water inside the unvented tank.  And it will connect to UFH as well.
There might be other reasons for not choosing it.
They have pretty cheap and nasty aluminium heat exchangers in them and a 2 year warranty as standard. For the money there are better boilers, and to get anything more than the 2 years you have to use a Vaillant installer.
